If you look at the link above you will see that the text in the middle of the screen (welcome to benefitness…) is displayed on a white background.
In freeway I have a graphic item which is dark grey in colour and the graphic box with the text in it is placed on top. However when viewed in the browser you cannot see the grey grpahic behind the text and the text is not displaying correctly.
Looks fine from here. Maybe a cache issue with your local browser? Try holding down the shift or option key while you press the Reload (curly-arrow) button in your browser.
Also consider using actual HTML text for this, rather than an image. Search engines cannot read images. You can get very close to this font using Google Fonts and the built-in Action.
On Sep 1, 2016, at 12:46 PM, Tony Farrer email@hidden wrote:
Hi,
