Sometime around 29/8/08 (at 22:58 -0400) Mark Horowitz said:
I have done what you suggest, but when I go to “edit styles” to
change one of the permanent ones, I have to scroll through all of
the permanent and temp ones. In the styles palette though, only the
permanent ones show.
Ahh, okay - I didn’t realise that you really wanted to eliminate
those styles. It will take some work, so think to yourself how many
times you need to edit styles and balance that with how long this
process will take.
(BTW, you can just right-click (control-click) a permanent style in
the Styles list and choose to edit it from there without having to
scroll through all the temporary ones in the main Edit Styles list.
Anyway…)
You’ll have to figure out which bits of text use those styles and
then apply new styles to them or delete the unwanted style, replacing
it with a wanted one instead.
If you right-click (control-click) one of those styles and choose to
delete it, you’ll be asked what style should replace it. You can pick
the No Style option or any other style in your list. The trouble is,
you really need to know what you’re going to affect by doing this!
Choose to edit the style rather than delete it out of hand, and you
can see what settings it has. If it is a graphic style then consider
renaming it to keep it out of the way in the list but not deleting
it. If it is a regular HTML style and you’re not sure where
throughout your site it is used, try this process:
1: Publish your document so all the pages in the Site panel are
‘clean’; they don’t have bullets next to them indicating unpublished
changes.
2: Go back into the Edit Style dialog and make a really obvious
change to the style in question. Setting the character colour to red
or green is often a good choice.
3: Click OK. Now every page that has text that uses this style will
be marked ‘dirty’ in the Site panel.
4: Take a look to see what text uses this style. You can either
reformat the text directly until there is no more text that uses it -
in which case the temporary style will simply disappear - or you can
delete the style and replace it with another, knowing exactly what
will be affected and what to use as the replacement.
5: Save, repeat.
k
