There’s now a standalone app that provides a nice GUI and a few
features to support the use of the LESS syntax for writing CSS that
works with the major editors. I helped the dev, Bryan Jones, with some
testing and such and I can tell you it’s a useful little tool. The
LESS project site is below.
Hi Todd
I also saw this a little while ago and wanted to have a go so I had a quick go at installing it.
Unfortunate I couldn’t get the command line to work correctly
$ sudo gem install less
I just got this
Macintosh:~ max$ sudo gem install less
Updating metadata for 1 gems from http://gems.rubyforge.org
complete
ERROR: could not find less locally or in a repository
with the obvious result that less didn’t work
did you have any problems with installing it
cheers for any info
Your copy of gem might not have the latest gem sources. If gem is up to date, then try this:
gem sources -a http://gems.github.com
gem install gemcutter
The first command will add github to your list of sources, the second will install a gem that manages your connection to the gemcutter repository, which is replacing github, which sorta replaced rubyforge as the canonical source of gems.
Ah…yeah, what Walter said. He beat me to it. Damn my need to
sleep. ; )
On Feb 4, 2010, at 6:53 AM, max wrote:
Hi Todd
Hi Todd
In case you’re interested, Sass http://sass-lang.com/ is another
flavor; very similar to LESS. Seems popular with the Rails crowd. The
end result is essentially the same. Cool stuff.
