I’m finding Intaglio to be a great way to make simple electronic schematics but could use more symbols than are in the sample libraries. Does anyone have a more complete electronic symbol library? I would also like to make pcb artwork but would need a library of pcb footprints… any out there? -thanks.
Have you considered converting the ClarisDraw Libraries?
No, they were included with the ClarisDraw software and are most
probably still under copyright, but should you obtain an old copy of
ClarisDraw I think that possession of the originals would let you
convert them for use in Intaglio. How about some other opinions here?
Are the Claris Draw libraries available for download? I just did a
quick search for a Claris Draw users group and didn’t find one.
Ok… it is a good idea though. I’ll ask around, I may have a friend with Claris Draw. One issue will be that the symbols are going to be very old but they should be a good starting point at least.
On Nov 28, 2010, at 8:33 AM, Jack Jennings wrote:
No, they were included with the ClarisDraw software and are most probably still under copyright, but should you obtain an old copy of ClarisDraw I think that possession of the originals would let you convert them for use in Intaglio. How about some other opinions here?
Are the Claris Draw libraries available for download? I just did a quick search for a Claris Draw users group and didn’t find one.
