links are not getting updated to https
Hi everyone.
I hope you guys may give me some light on this.
I just finished a website I was working on and uploaded, and it was working perfectly.
The website has a drop-down menu with attention and transition actions and also a target show-hide gallery and smooth menu.
Today, I realized that they had that odd “Not Secure” phrase before the address and I chatted with them requested to enable the SSL.
However, after they did it and changed it to https instead of Http all the effects, the drop-down menu, the slideshow and smooth menu were gone.
I chatted with them again and they basically said it is not their problem and this is something I need to check it from my end because it is a custom coded website. I required them to deactivate the SSL again until I find a solution and now it’s working.
What I understand is that somehow Freeway is not writing the code properly compatible with https ?
Any ideas how can I fix this
Thanks, Marcus
Hi Marcus,
Some of the Actions that you use are outputting http links.
This thread should help:
https://freewaytalk.softpress.com/thread/view/176783#m_176791
Jeremy
Thanks, Jeremy, as soon as I can I will look at this thread. I hope I can solve it, and if I have any problem I will let you know
thanks again!
Marcus
Thanks, Jeremy!
That worked.
Marcus
