I have a problem with newsletters… When I make the code it works in freeway and upload to my server it works via browser, but when I insert the code in my mail program to make the newsletter, links doesnt work. I work with 1and1.es, and the say that its a problem in my code but dont know what. Before freeway I used to make newsletters with dreamweaver, and it worked ok.
I give a link. Please, can someone take a look to see what is wrong?
Hi, I just tried sending the page to myself and it works fine. I’ve just sent one to your address, can you check it to see if the links are working there? If they aren’t, can you let me know which mail client are you using?
Hello. After making thousands of different things I discovered that a couple of weeks ago, I reinstall the computer, and with the internet explorer I am now using the mail server application doesnt work properly!!
