http://stepbeyond2.co.uk/test/goodfoodfast.html
In the centre of the page the right-hand column shows four recipe images plus titles. Each has a link which doesn’t work.
What have I done wrong and how can I rectify this problem?
Many thanks.
BigG1
(BigG)
2
Try selecting the text, remove the link, reapply the text style and reapply the link - see if that works.
Nathan Garner
FW5 Pro | MacBook Pro | Snow Leopard
Many thanks.
Have a look at Div Item12 - does it overlap the others containing the links?
Try sending it to back and see if that does the trick.
