I’m trying to view the Freeway 4 Graphics Tutorial, but it will not load for me, is there a problem?
Hate to break it to you Martin, but Freeway 4 is a bit out of date. We are
at version 7 now.
I’m not saying that’s why you’re having trouble viewing the version 4
tutorial - I honestly don’t know. But I can be more helpful if you post
your question back in time several years, and perhaps include a link to
this tutorial.
Urmmmmm, yes, I am aware of that! I don’t have version 4! However, I need some help with Graphics and have used this tutorial previously…
Is there a more current tutorial video about using Graphics?
What specifically do you need help with - remember that the question has likely been asked here before.
That I don’t know what is available - but I do know that there are a lot of
Softpress video tutorials already on YouTube… perhaps searching there will
be helpful.
Thanks, that YouTube video is exactly what I was trying to find…
This has been documented in different threads before. If you open a FW6 files in FW7 it will create a fw6 backup for you, but it may or may not work in FW7.
My suggestion is to keep FW6 for the old sites and use FW7 for the new sites that you will start to build. That is what I do
