I have a few .style1, .style2 etc. in my site which is a big site. Is there a way of locating where these styles are used in the FW doc. rather than just deleting and replacing them as I want to make sure nothing is pulled out of place when I do delete them.
Temporarily change style1 to something obviously different from any other style, so it will stand out (make it a colour that’s not used for this site, for instance).
All pages that use style1 will now have dots before their names in the list: on one of these pages it’s easy to find all the instances of style1 and replace it with an existing style or simply remove it as necessary.
I do have all my styles set-up. But, when I select some text that is already styled and retype something then a new .style is added.
Yes, this is just one of the situations where Freeway creates a new style for apparently no reason. I’m always on the lookout for this and try to kill the style at once.
I really don’t know why a new style is created. This happens when the text style has settings both for Character and Paragraph: select a word and retype and a new temporary style is created, that has the same character settings as the original style but no paragraph settings. In the last site I did, I made sure that my styles only had settings either for Character or for Paragraph, but not for both.
Michael
I have applied this method but for me all pages get a dot before it even if the altered style is not present on that page. Any one know a reason for this?
Do you have your site set to use External Stylesheets in the Site
Preferences? That could cause this behavior.
a reason for this?
I do not see reference to External Stylesheets in the Preferences but I do see one in Document Set Up. There it is unticked. Should I be looking anywhere else?
