Thanks Walter. This will certainly come in handy if I end up having to roll my own solution. I’m still hoping I can find an off the shelf solution that I don’t have to write, debug and maintain.
Tim
Sent from my phone
Walter Lee Davis email@hidden wrote:
Did you see this gist I posted a couple weeks ago?
https://gist.github.com/4520957
On Jan 27, 2013, at 2:50 PM, Tim Plumb wrote:
I’m putting together a site for a client and I’m looking for a simple, bare bones, event listing system that she can use to add events to easily. The closest thing I’ve found is the following script which is almost perfect but requires a MySQL backend;
http://newsscriptphp.com/eventscriptphp/demo_eventscript.phpWhat I’m looking for is;
- Runs on PHP
- Flat file (any format - XML, CSV etc)
- Admin interface to allow her to add, edit and remove items
- Allows events to be listed n per page
- Past events should be automatically trimmed
I’m very tempted to code this myself as I’ve most of what I need although the budget won’t cover it if I do. Unfortunately the flat file requirement comes from the fact that she has a rather limiting hosting account which also runs several other sites and tools.
If anyone has any great pointers then I’d love to hear about them.
Tim.Experienced Freeway designer for hire - http://www.freewayactions.com
