Thanks Max. Other than the events post not automatically removing itself after the event date I think it is pretty close. I’ll give this some thought.
Tim
Hi tim it’s sort of what I created for photographer friend, but in her case she needed to create a blog type area and its almost the same structure
In her example the items were webyep items within a webyep loop and those specific block had a read more link page. The only difference is in my example I just made it look like a blog layout, and I added a feed-back form on the linked read more pages for people to leave there comments. The layout of your example looks something like a normal webyep loop to me. This is my example:
You could make the event at least hide using WebYep. The key is using the plain text field to capture a date from the user to process, validate and store the date back into WepYep plain text field to use again check the system time/date and use php hide the display event div and show ‘event over’.
I’ve done a few mini apps using WebYep to do things like this. You’ll need to know a few little api’s to make it work.
Tim
Hi Tim
David is quite correct the start and end date can also be added quite easily…
here is quick screen shot showing how the start and and end date would look like in edit mode
