Is there an easy way to show square meters in Freeway, instead of using a MarkUp with the code m2 everytime?
There may be other ways, but this works: type ‘m2’ then select the ‘2’
and go Style>Shift>+1
(that’s the ‘Style’ menu at the top, btw.)
best wishes,
Paul Bradforth
Perfect, thanks Paul!
Op 26 jun 2008, om 14:57 heeft Paul Bradforth het volgende geschreven:
using a MarkUp with the code m2 everytime?There may be other ways, but this works: type ‘m2’ then select the ‘2’
(that’s the ‘Style’ menu at the top, btw.)best wishes,
Paul Bradforth
