Hi. I was wondering if anyone had any expertise with MacBook Pro fans. I know fan noise is not a good indicator. However, I have a huge project due on the 22nd and cannot give up my computer.
My question is simply how bad of a problem is fan noise? I’d say that it’s medium loud.
Also, is there a way I could use a compressed air can to clean the fan and still keep using my computer until the 22nd?
Thanks for your advice.
