GUTTED for that could have the problem but alas seems ok
http://inspiringyourchi.com/malsettings3.cfg
seems ok
Yes - but why is it called malsettings3.cfg ???
That is not the file that Mals is looking for!
Clean that file out of your site folder and publish again and make sure that you only get malsettings.cfg
I didnt generate this file did I? Haha not sure!
No - the action does it for you.
Right so why is this doing this then?
Too much f***ing about!
But seriously - this does happen sometimes.
Clear out the old versions and republish.
It’s because there were already malssettings.cfg, malssettings1.cfg, and malssettings2.cfg in the site folder. This happens all the time when Actions make files. They lose track of the ones they already made, and since they cannot overwrite a file they didn’t make themselves, are forced by the Mac OS filesystem to re-name the file they are making and try again.
Right - there was no extra files it only creates malsettings3.cfg - ??? So I manually make it malsettings.cfg and I can now get the button to work here (click orange add to cart button)
http://inspiringyourchi.com/loverelationship.html
But the WebYep version (which I need cause the client wants to edit) will not work wether or not I have the link verification on or off - I know that to get this to work I need this turned off - but just to show that it does work with the link above I kept it on…
When I tried the WepYep version with the link verification version off - I get
ERROR: Link verification failed.
