Thanks so much for the help I have got!
My problem now is that I have a master 1 with several graphic items. Some way they have moved a bit in some of the pages. How do I make them all come to the same place?
Warmly Else
Hi Else
In the inspector palette under Properties when you click on an item that is on your Master page then on the pages themselves you will see 2 checkboxes
Use Master Content
Use Master Settings
If these are ticked then they will revert to the settings/content the same as your Master page.
Hi David
Thank you so much - it was so easy when you know what to do!
Warm wishes Else
