Tried to send a message via your easiForms webpage contact form. For whatever reasons, the server keeps dropping my connections to submit my content.
Safari can’t open the page “Easibase: Contact Form Sent because the server unexpectedly dropped the connection. This sometimes occurs when the server is busy. Wait for a few minutes, and then try again.
I’ve waited several times within several hours and nothing resolved the issue.
My inquiry…
-Is easiForm and easiCaptcha compatible with Freeway Pro 5? It states Freeway 4+Pro on the easiForms page.
-Is there a Pro 5 user tutorial for both actions?
-What are the current versions of easiForms and easiCaptcha?
-What type of forms can a user create? Contact forms, Feedback forms, Application forms, etc.?
-Do you offer a discount on multiple license purchased? I have several domains. Thanks much-Dave
For whatever reasons, my message went through. After re-visiting my email, I received three email confirmations that my enquiry has been sent. Weird. I did in fact submit my enquiry three times, due to the message received from Safari…
“Safari can’t open the page “Easibase: Contact Form Sent because the server unexpectedly dropped the connection. This sometimes occurs when the server is busy. Wait for a few minutes, and then try again.”
which explains the three submits. Must be my service provider. They tend to drop the ball at times.
I think you maybe have had some issues at your end as I have received
the emails but of course I cannot be sure, I received 3 messages from
your email address and all with the same questions and with sent time
over 45 minutes between the 3… anyway, you should have a reply to
one of those 3 emails by now which I paste below:
Generally the actions are used for contact and feedback forms or
collecting information from your users.
A license is per domain, as many forms as you like on the same
domain. easiForm $20, easiCaptcha $15, easiForm & easiCaptcha bundle
$30, there are discounts for 5 copies or more work out at $27 a bundle.
Before you buy I suggest you set up your form using the actions then
make sure your server is all OK with ioncube, some do not support it.
If you have any questions just drop me an email.
” because the server unexpectedly dropped the connection. This
