mm ruler scale labelled every 92mm!
Whenever I set the scale to millimeters, the ruler is divided into 92mm segments. Why? Surely it should be in 100mm increments.
Or am I doing something wrong?
Intaglio mailing list
Not quite sure.
Have you tried to adjust the “graphic raster” under menu-> Layout to 10mm already?
http://img607.imageshack.us/img607/2537/raster.png
Frank
Thanks Frank. My grid is set to 10mm, but the scale numbers are very odd!
See:
http://dl.dropbox.com/u/7745570/IntaglioScreenSnapz001.jpg
I have not been able to get this to number in 10s or 100s.
You have to synchronize “Measurements…+Dimensions…” as well then:
http://img526.imageshack.us/img526/2627/unitsync.jpg
Frank
