mobile website help
i have a question… i have a website made using freeway… its not mobile friendly and i have come to terms that i have to make google happy…
can anyone help me how i can make a website which looks like
www.kif-kifimport.com or www.artemano.ca?
Artemano has a really neat menu which appears on the side… is that doable in freeway?
Any help would be awesome. Thank you in advance.
www.rusticfurnitureoutlet.ca
If you are referring to the Mobile specific menu then yes you can certainly do that in FW7 using the Responsive CSS menu action that is built in.
ok being completely dim here…
open icon… is there supposed to be something click? what does this open icon exactly mean?
same question for the close icon
menu entrance location… can you explain where this is exactly?
is there a ressource for people like me that we can use to understand more?
You have the option to choose the icon that is displayed as the open/close icons when the mobile friendly version of the menu appears. Or stick with the standard one.
Do you want the menu to slide in from the top or left
I guess we like to call such a resource a ‘manual’, and you can read all about it here: http://download2.softpress.com/docs/Extended_Reference_For_FW7.pdf
Richard
last question… template http://marketplace.softpress.com/templates/floral/
is that easy to play with and adjust to suit my needs?
As long as you only adjust the given items (color, images and text) YES - but if you need to add or remove things - absolutely NO. This is no sarcasm - just the experience of watching “adjusted” templates all over the (market)place (but not only there).
But who knows your skills?
Is there another commerce template out there that i can buy to adjust? Is there a user out there who would be willing to sell me their template so i can start with proper formats etc etc…
