Hiya,
I have used the moo slimbox action in a site gallery but the little ‘X’ in the corner is not showing to close the box.
http://nlgdesign.co.uk/castlerising/gallery.html
Any ideas???
Thanks in advance
Nige.
How are you uploading your site? The closelabel.gif file is missing from your Resources folder.
Hi David,
Thanks for looking. I uploaded the site with freeways upload function. I will look for the gif and place it in manually.
Regards
Nige.
Strange. Before you do that try holding down the Control Key and File>Publish Everything.
Then do a fresh upload.
Hi,
Ctl - File/Publish doesn’t seem to have made a difference. I’l look for the file and upload it by hand.
nige.
File>Publish Everything is what you are looking for.
After doing that is the closelabel.gif in the Resources folder?
HI,
Sorry, that’s what I meant. I found the file in the resources but it was called closelabela.gif so i removed the ‘a’ and it works now.
ta
nige
It is normal for FW to create duplicate graphics and tag a, b etc on the end but the Action (moo slimbox) should keep track of that and compensate.
Any particular reason you are using Moo?
Hi,
No real reason for moo other than it’s quite easy to use
nige
Yes but it conflicts with the native Script/Protaculous actions that FW ships with and that provide so much more.
You cant use them both on the same page.
More than likely there is an alternative which will not have issues.
Try ScriptyLightbox - available at actionsforge.com
Quick example http://deltadesign.co/fw_examples/fwactions/scriptylightbox.html
