I believe all the installer does when simply mounted as a volume on the
Desktop is reset the startup disk preference pane to the DVD and initiate a
restart.
The Special boot system on the DVD then opens you inside the installer from
which one normally proceeds as instructed (but there are some other options
from the installer DVD in the top menu such as reset password and running
DiskUtility).
But if alt (option) key held when restarting with the DVD in doesn’t ‘see’
the system on the DVD and give you the opportunity to choose it to Boot from
then I wonder if your DVD is in fact good - or if your optical drive is
adequate to see it.
Apart from examining and cleaning DVD and the optical drive I don’t know
much else to offer.
To reset the p-ram hold apple alt p and r keys immediately after the chime
and hold until you hear another chime (some hold for two more chimes).
This will reset the screen resolution and mouse setting to defaults but
nothing onerous to put back.
If I was local I would gladly assist.
If you have a friend with a Mac that will boot from the DVD and your Macs
are firewire enabled to do so, then you can set your Mac up as a firewire
target disk and install from the DVD via their Mac. (All recent Macs).
You could do a similar thing if installing onto an external firewire
partition and then cloning - from that to yours - but then you have to back
everything up for sure and erase install and manually transfer your data
back. This would be a faff and not a first resort!
But I think the experience of Mac OSX on Panther and Tiger is significantly
better than Jaguar. At least I found it markedly so.
And reports are that both run better even on older Macs than Jaguar in
almost all cases.
Computers remain capable of branching into any and every distraction and
frustration. Mac or Pc, old or new. Starting on a good footing is perhaps
the ultimate philosophical offering to close with. Because from a false or
unrealised mistake - all of the rest MUST fail.
Therefore there are times to pause, release and rest and become freshly
inspired.
with all good wishes
Brian
hugh said recently:
Thank you Bin-Ra for the philosophic musing, which I know is well
intended…and, in fact, well taken.
Yes, I must persevere. Sometimes, though, it’s just so time consuming going
nowhere that it feels like you’re going backwards.
To everyone, thanks for the tips. I have tried booting with the C key held
down but still get the normal startup routine and disk - so it obviously won’t
boot from the DVD.
I can’t see why the machine should not be able to read the DVD or boot from it
- it does open, I can see the files and it even starts the installer.
I think David mentioned a PRAM problem?..just what problem might that be?
regards to all
Hugh
