Okay, so I’m trying to use the E-phonics player but I don’t get how to put it into Freeway.
Here are part of the instructions:
1.) In the head of the page we include the SWFObject script:
Question 1: Would I do that under Page > HTML Markup > Before Head or After Head or what? I have no idea. Is using Page > HTML Markup even the right thing to use for this?
2.) If you want to use the Javascript API to control the player you should also include the ep_player.js script:
Question 2: What does that mean? Since I don’t even know what API means I think I’ll stay away from that.
3.) In the body of the page we include the MP3 Player code: First we set the alternative content for people who don’t have javascript turned on or have an old Flash Player.
Question 3: How do I put that in, just with an HTML item?
4.) Now we set the Flash Movie and its parameters.
Question 4: Same question–What do I use to put that in? Also, it seems to me that 3 needs to be behind 4 so if people don’t have Javascript enabled or the Flash player they will see the alternative content in place of the player, so does one sit on top of the other?
Really, I’m very confused. If someone wants to help me with this via email, I’ll pay you $50 through Paypal or with a credit card if you accept them. You can get an extra stocking stuffer for someone for Christnmas. If it takes a long time I’ll pay you more. I just want to get his done.
One of my testers said the other player is now working on Windows with IE. I may have fixed it. I’m not 100% sure yet. I can’t get a hold of any of my other testers right now.
Thank you.
