No READER icon on the right side of URL
Hello all again
The READER icon (URL on the right side) appears on this page: http://www.bajanapple.com/aboutbajanappleb.html but not the home page: http://www.bajanapple.com/index.html. any reason why its dosn’t appear on the home page?
Thanks in advance
Tony
Hi Tony.
I had a similar issue recently and Walter pointed out my misunderstanding of the Reader Function in Safari for me - no doubt he will chip in if i’m wrong.
The appearance of ‘Reader’ is dependent on the amount of text that appears within the div on the page. As your first link points to a page with far more text than your index.html page, i would suspect that is the reason.
You could text by adding more text inside the same div to see if it triggers the Reader function.
I am not sure what the text character count is, but you will soon see.
Hope this helps.
Al…
Thanks Alan.
I’ll have to find out the min amount of words to trigger READER to kick in as this makes far more pleasant to read on a small device.
thanks again
Tony
