When applying shadow to a linked pass-through graphic (or any other graphic object I suppose) the smoothscroll action stops working.
Any workaround for this propblem?
Not directly. The issue is that when you apply a smooth shadow to a graphic, it stops being rectangular, and Freeway responds by creating an image map for it. Map targets cannot be linked the way that regular (id-based) anchors can.
There are some work-arounds:
You can export the image and its shadow as a PNG or JPEG, then import that image as a new pass-through graphic. Because the new rectangle will include the shadow, you won’t have any issue with the smooth scroll. Watch out for mixed backgrounds if you do this. PNG-24 (millions of colors, in Freeway parlance) will preserve semi-transparent shadows, but JPEG and PNG-8 will not. Instead, they will sample a single spot on the background and use that to composite the entire shadow area, which may look odd or awful.
You can use CSS shadows instead of the image-based shadows. Make sure that the element is an HTML box (green borders) rather than a graphic box (blue borders) and then apply a simple shadow using the style tab of the Inspector. CSS shadows will not turn the box into a map target. However, CSS shadows can only be applied to pure rectangle images, unlike graphic-based shadows, which can wrap around irregular shapes based on transparency in the original image.
In psychology and other faculties one is encouraged to think outside the box to get better and faster results. And in this case this is what I should have done. Quite literally.
In other words, alternative 1 does the job perfectly.
Alernative 2 is more complicated as my linked box is a graphic and not an html.
Thank you, Walter. Muchly appreciated.
