overlap problem
Good Sunday Evening.
Quick question - I know there is an “easy” solution… but I cant get my head around it.
I did a site:
http://www.sunsvigor.com
on the front I have been told that the bullets on the right of the showcase are overlapping the paragraphs to the left of the showcase. This seems to only happen in IE (at leastV. 7)
How can i fix this so it doesn’t happen.
Thank you very much!
Julie
Overlapping layers!
Remember the Safari thing about increasing the text size to see where a site is going to fall apart?
View>Zoom Text Only and increase the font size a couple of notches. Typically IE and PCs render text a bit larger.
I forgot.
I am using the rpl action… Do som reason I thought that helped solve that…
So how do I have it where I want it on safari ff. But fix
It so it looks good for
Ie?
I am blanking sorry long weekend.
Thank you
J
Sent from my iPhone
On Nov 7, 2010, at 18:26, DeltaDave email@hidden wrote:
Overlapping layers!
I apologize, fat fingers
FOr some reason, I thought the RPL action helped prevent this issue… with other sites I have done with this action I been able to increase (command +) and all increased nicely.
what am i doing wrong with this one?
Julie
Is everything on your page a layer? If you have any non layered items, RPL will ignore it.
If you increase the text on that front page, there’s overlapping in the left column with “Ask and you shall receive” area.
Bob
It looks like the item containing the bullets is overlapping the main item called body1. Make body1 wider so it can accommodate item3 (the item with the bullets) without item3 sitting on the right edge of body1.
More details in the RPL KnowledgeBase article:
http://www.softpress.com/kb/questions/238/Using+the+Relative+Page+Layout+Action+(Freeway+5.5+Pro+only)
Bob
I have all as layered.
I have rpl on the folder not on the page. Is that ok?
Also, when I increase on safari and ff I see no overlapping.
Julie
Sent from my iPhone
Bob
Thank you so much I will work on that
J
Sent from my iPhone
Bob
I fixed that and uploaded.
does that work better?
Thank you for all of your input.
Julie
J
Sent from my iPhone
Bob
Good AFternoon,
I did as stated above from Joe - but I jst looked at a site on an imac and the lower portion of text is being pushed way down. How can I correct this? I increased item 1 to fit item 3 and it looked fine on mine - but on here (safari) it is all out of wack.
I also am seeing the same problem on http://www.energychex.com
services page.
I am using RPL on both. please help!! I am very upset - I thought i followed the RPL rules
Julie
Julie, the energychex site looks like it works as expected. Everything gets pushed down, no overlaps.
I’m in Forefox on Mac.
Thank you - I saw it and the boxes that should be 2 top row, 2 second row 2 third
instead are all in one row going down on left.
is that what you are not seeing?
are you seeing the problem still w sunsvigor?
Thank you
J
Yes, I still see the text overlapping in the left column between the signature, email , and following head.
I tried to do as joe suggested…
any other suggestions on how to fix this? Please
thanks
J
Julie, it looks like there’s a big gap in that left column now.
Can you send me the Freeway file? Even just that page in the file.
I’m sure others know way more than me around here, but maybe it just needs a fresh pair of eyes.
Do you still have my email address?
Bob
Yes I do.
Thank you.
J
Sent from my iPhone
Bob
