Page loading issue
Page no longer loads; only partial upper right corner. Didn’t change anything from the spring and after editing file for fall version, was no longer able to either successfully publish it or even preview the page in FP v7. Also getting strange error message when publishing… "ACTION CANNOT BE USED: The following Actions have been incorrectly applied and will be ignored. Action: “PHP feedback form”, Page: “contact”.
Nothing changed from last version… having same issue with backup copy.
http://gtraingbuildings.com
Does anyone know what the problem is?
The page is really slow to load. It has some large graphics that could be optimised. Are there other issues?
Jeremy
Don’t know… worked beautifully for years until now.
It seems to have lost its DNS entry, or you have maybe mis-typed the URL. I get nothing, because the DNS does not resolve that name to an address.
dig gtraingbuildings.com
; <<>> DiG 9.8.3-P1 <<>> gtraingbuildings.com
;; global options: +cmd
;; Got answer:
;; ->>HEADER<<- opcode: QUERY, status: NXDOMAIN, id: 43876
;; flags: qr rd ra; QUERY: 1, ANSWER: 0, AUTHORITY: 1, ADDITIONAL: 0
;; QUESTION SECTION:
;gtraingbuildings.com. IN A
;; AUTHORITY SECTION:
com. 900 IN SOA a.gtld-servers.net. nstld.verisign-grs.com. 1510789333 1800 900 604800 86400
;; Query time: 216 msec
;; SERVER: 208.67.222.222#53(208.67.222.222)
;; WHEN: Wed Nov 15 18:42:28 2017
;; MSG SIZE rcvd: 114
If you’ve not looked at dig output before, that is saying that it looked everywhere – all the way to the top of the tree at verisign, and found no A records for that domain.
So sorry…
www.gtrainbuildings.com
Which loads immediately here. Where is it hosted? Are you half a world away from its physical location? Every page is snappy-loading immediately here.
On Nov 15, 2017, at 6:48 PM, peterpica email@hidden wrote:
So sorry…
Dunno. I do for friend on left coast. I’m on right coast, USA. Still having issues with FP7. Unable to preview my home page… Only getting top right image area. The same way it initially appears using Firefox, Chrome and safari. Takes forever to load. Was trying to update home page that’s worked for years without any problems. Totally confused on this side of the pond. :hushed:
… remove this counter or whatever it is called (sitemeter.com). Their site is as reachable as yours!!! It’s 80ish technology anyway.
Take over 60 seconds plus to load the home page for me. Safari Inspector throws up the error…
[Error] Failed to load resource: The request timed out. (counter.js, line 0) http://s50.sitemeter.com/js/counter.js?site=s50structures
David Owen { Freeway Friendly Web hosting and Domains }
http://www.ineedwebhosting.co.uk | http://www.PrintlineAdvertising.co.uk
Aha. I have Ghostery running on my Mac, so that wouldn’t have loaded anyway. That explains why I see it immediately.
Thanks for tracking this down!
Jeremy
