Any comments on the following website would be gratefully recieved.
Thank you
Thank you
Hi Mark,
This is a nicely put together site. I like the fact that you placed a different ‘banner’ photo on each page, complementing the conservancy theme.
The suggestion I have is to consider creating a background (solid color, gradient or photo) which will fill the visitor’s browser window.
Cheers, Jim
Thanks for that Jim
Mark
Mark
Nice clean layout.
I agree with Jim, a simple graduated background will make the pages pop a bit more.
Marcel
Nice Clean site - bet the dormouse was confused when it woke up somewhere else tho !
I know meta tags are not as important as they used to be, but perhaps you should add a Description tag to the homepage - gives the search engines something to show when they list your site.
Hi Mark,
I also liked the website. Very easy to read. The pictures are great, I would encourage you to add a few more, maybe before and after if appropriate. They are a powerful tool to illustrate to clients what you do.
This is not a technical comment, but an editorial one. Your caption under case 1 says granary conversation. Wasn’t sure if that should read granary conversion instead.
Thanks for the comments. Most appreciated. Nearly finished now.
Mark
