It makes coverflow flash files and you can place the swf in freeway pro no problem. but you will only see grey boarders and no pictures inside… Is some HTML Markp needed?
I don’t think so, you just need to upload your images and files
separately. You should have a folder of items that PhotoFlow created,
place the items alongside your HTML files on your FTP server using an
FTP app such as Transmit: http://www.panic.com.
If this doesn’t work, move them into your Resources folder (this is
where the SWF file lives, the files either need to be with the page or
the SWF, I can’t tell which without seeing them though).
