php form problem
keep wondering what i’m doing wrong here… the form won’t work, even if i do a simple copy paste from the whole contact page of other sites wich work.
I know, that if i’m setting a error page on the php feedback action, the page won’t load to the server, but keeps yelling to met something with a 43 error.
i’m already somewhere what’s called deleting the page.
ps, don’t try the contact link on the page, it’s redericting u to a page where it works
http://pvcvloergroningen.nl/contact.html
Try removing the Action from the page, publishing once, and uploading. If that works, then you have incriminated the Action (which is really probably not the issue). Then add the Action to the page again, re-set the options in the Actions palette, and publish and upload again. If that works, then you have cleared the issue.
If you don’t make it past the first step, the zip the document and send it to support(a)softpress.com for dissection.
I am not seeing a form being set on that page.
yuw, should be now again… but still changes cause i’m still trying to solve
