I had some great advice earlier, which has meant I have managed to put up a series of pictures that fade in on my page. However, every time I change anything, it seems to upset the images, so when I look at it in the browser, the fading has stopped, or it no longer works and you get a blank box with the name of the pic. Is there anyway of stopping this?? or when I publish it will it be resolved anyhow? help! : )
I’ve found that, too. I think it’s a bug somewhere, but I can’t be sure.
The workaround I found was to force publish the site each time you
want to preview it. You can do this by holding Control while you
choose Publish from the File menu.
Once the site’s uploaded somewhere, the problem seems to go away. I’ll
see if I can pin down some repeatable steps for the problem and get a
bug logged at Softpress Towers.
