I am working on that dang jewelry website lol.
I did passthrough png’s for clarity I am told thAt he is seeing rough edged black background. How is this possible and what am I doing wrong
Ps there are pictures w scripty lightbox2… When u look at pieces.
Unsure If he is seeing that.
Any help would be great…
Ps I know
My layout is still a work in progress but getting there’s
Sent from my iPhone
He is using a stooopid PC with a really old version of IE, my guess.
doing wrong
LOL That is what I am thinking. LOL
how do they all look including the SL2 pictures crisp clear?
Thanks!
I would stick to JPEG while you’re showing them to your client. The
only reason to use PNG for this is if you are zeroing out the
background and then overlaying it on a mixed background. Even then,
you can get Freeway to composite a matching background finto the HPEG
or you, and then you have the browser support of JPEG along with faux
transparency.
with the white background the pictures were helping make the site look heavy. I totally agree with all on my question last night.
Also, the pictures look bad on the white background - almost as bad as before i removed the background of all the pictures.
I have no problem with using the jpeg on the sl2 pictures, just the ones on the store and the landing pages from catigories.
I know my layout is not great still. but I am trying to make at leat the pictures pop - in a good sense
J
Thanks!
I think I found the culprit picture (at least one) and I left it PNG but I colored the box in the same color as the background. I hope that works also.
J
On Sep 9, 2011, at 9:54 PM, Julie Maxwell Allen wrote:
Ok, how do you do that?
J
Thanks!
If the background is a solid color, then you can make it a JPEG.
Freeway will add in the background color you apply to the image, or if
you have the image over another image, it will burn in a copy of the
image beneath the knockout image, so you see the exact aligned
background behind your image.
that works also.
J
J
Thanks!
guess.
doing wrong
