Intaglio 2.9.8:
To create a polygon with rounded corners, draw the shape with either the Rectangle, Polygon or Path tools and in the Stroke palette, click Round Join (the centre icon).
To increase the size (diameter) of the rounded corners, make the stroke wider.
Well, I may be on the wrong track - and with vs. 3 - but as can be seen here: mac.abc.se/home/onesr/pic/intgl/polygon.jpg
I still cannot make it work (rounded corners in polygons).
I’ve looked at your screen capture. The first thing to mention is that you’re selecting the round stroke “join” option. This will give you rounded (instead of mitered) corners in the stroke where two path lines meet. I’d say that’s what you’re getting for the six sided polygon (although the effect is subtle on lines that thin). For the triangle you’re not getting the round join, but due to the white flecks in the corners where the stroke isn’t completely filling I’d guess this isn’t a normal path anymore so that probably explains it. If you set the polygon tool to draw a three sided polygon and use the same stroke width and join settings you should see round corners.
Since you’re using version 3 you can double click on the polygon tool icon to open the polygon tool adjustment window and move the slider labeled “Curves On Points” to get rounded corners on polygons.
I think there is a problem with the polygon tool and the strocke
options :
with the 3 stroke option I have the same result : only round
corners ; sometimes I could change the option, but now I cannot any more
with the polygon tool I can change the sides of the polygon, but not
the corners !
jacques
intaglio 3.0.1, mac os 10.4.11
Hi,
Just wanted to wave the green (?!) flag and tell everyone that it is working now:
Rounded corners can be applied no problems for the triangles & other polygons with the Stroke → Join / Inspector.
(It did not want to do it yesterday, I have no idea why not ,
maybe because it was a Monday?
or is my computer?)
with the polygon tool I can change the sides of the polygon, but not the corners
As Nick was saying, with version 3 “you can double click on the polygon tool icon to open the polygon tool adjustment window and move the slider labeled “Curves On Points” to get rounded corners on polygons.”
Please tell us again if you have a similar issue, where something in the application works but sometimes refuses to do what is expected!
On Oct 8, 2008, at 2:27 AM, Jacques Villars wrote:
I don’t find the pref’s or cache of Intaglio, so I cannot delete
them ; I have deleted the whole intaglio repertory in application
supports, but with no effect ; in one of my mac os sessions every
thing is ok, but in my ordinary session not ; I send you screen
copies of the two resultings strokes, bad ones and right ones :
(2 folders : intaglio bad and intaglio ok)
(I don’t know the e-mail adress of Omar : the bad resulting
strokes in triangles are the same as yours, comic lines and white
flecks in the corners)
There’s no specific cache. As you note, there’s a folder within
your user home folder at Home > Library > Application Support >
Intaglio. The preferences file is Home > Library > Preferences >
com.PurgatoryDesign.Intaglio.plist.
The images you sent look like a bug in the Mac OS X drawing library
called Quartz. If you’re using Intaglio version 3 on Leopard this
may be a bug in a new Quartz feature called QuartzGL that uses your
graphics card to attempt to accelerate 2D drawing. You can disable
this from the terminal while Intaglio isn’t running by entering the
following command:
defaults write com.PurgatoryDesign.Intaglio UseQuartzGL -bool NO
This change is stored in the preferences file so if you delete the
file you’ll undo the change above (or you can change NO to YES to
revert to the original setting).
If this makes a difference for you please let me know.
I have tried the command above, but with no result ! I have Panther,
not Leopard, is that command usefull ?
I tried also to delete the .plist file in the preference folder ; no
difference
Welcome to Darwin!
Ordinateur-Jacques:~ jacques$ defaults write
but when I open the .plist file (in TextEdit) and search for the
command I cannot find :
What is wrong ?
jacques
library called Quartz. If you’re using Intaglio version 3 on
Leopard this may be a bug in a new Quartz feature called QuartzGL
that uses your graphics card to attempt to accelerate 2D drawing.
You can disable this from the terminal while Intaglio isn’t
running by entering the following command:
Panther, not Leopard, is that command usefull ?
no difference
A plist (property list) file isn’t a standard text file so opening it in TextEdit isn’t always helpful. Various tools are available to read these. If you’ve installed the developer tools there’s an application called “Property List Editor” which is designed to read plists. Otherwise any XML reader can do it.
Jacques, have you tried trashing both sets of preferences?
what are the both sets ? the two files : Home/Library/Preferences/com.PurgatoryDesign.Intaglio.plist. in my two accounts on the imac ?; I think it is your suggestion, so I just have deleted them both, and now I have again the rounded corners again but I don’t understand why an altered prefs file in one account can produce a bug in another account !
Yes!
Because creating another account is like having another computer on the same machine. If set-up preferences become corrupt on one account, they won’t mess up on another. For example my wife and children have their own set-ups- all on my wife’s computer. The kids can have a totally chaotic desktop whereas, my wife’s, can be ordered and clear of clutter. If the kids’ account messes up, it won’t effect other users on the computer.
I also use my MBP here for home stuff- such as writing this mail to you, and I also take my MBP to work with me- opening up another account. FWIW, 10.5 Leopard takes this to a new level altogether, and having ‘cover-flow’ and ‘spaces’ is a godsend! :¬) :¬) :¬) %¬)
Try it!
