Most people here I would imagine are up to date on their copies of
Intaglio ( who wants the bugs of an older version?), so you maybe put
of luck.
In my experience, it is better if you learn to draw these items
yourself, as it really improves your understanding of Intaglio. They
will not be difficult to draw and I would use the group function where
necessary to lock all your drawn lines and things together. You can
also drag and copy or import different drawings straight into
Intaglio. I use a dedicated folder in my documents folder entirely for
Intaglio use only.
I hope that helps
regards,
Tom
Sent from my iPhone
On 7 Jun 2009, at 07:51, “Dave” email@hidden wrote:
Hi, I’m starting a landscaping project. Does anyone have some pre-
drawn bushes, trees, fences, sprinklers, and all that? I’m using
Intaglio 2.9.8.
I found a downloadable library on the Intaglio website, but it is
not recognizable by v 2.9.8, I guess it is only for v3.
Maybe you have already drawn these items and can share? This is for
personal use, just my own yard. Doesn’t need to be fancy.
