I want to create two WOW Sliders on a single FWP page. One would be used for mobile devices, the other for everything else. Has anyone been able to get two WOW Sliders on a single FWP page?
create two galleries saved in the same folder to prevent naming screw-ups.
Run then the video which you can find in the lounge (Stone Oven Template - Episode #005) which is about the show/hide using display:none technique.
Hey Thomas. Yes, I know about the show/hide technique.
The problem is that although I can create two WOW Slider documents without any problem, both documents create files (data, engine, index, etc.) which are named the same, with one batching writing over the other, thus rendering one of the WOW Sliders ineffective.
It seems like the app would know that, but apparently not. Or, I’m simply doing something wrong.
Ahmm - forget the same folder advice.
I think, that you need to publish them in separate folders but make sure, that you set in the properties → publish (last point at the bottom) for each slider a unique ID (1 and 2).
This should theoretically build two different (independent) working slider-sets with each different code stuff (theoretically).
Please note that I never really built a WOW slider
