The page in the example is made in wordpress. The client can log in and type text that after upload looks like a blog kind of thing (see the example and you see what I mean).
There are several CMS add-ons that you can choose from in Freeway. This seems like something you could use Perch, Pulse, WebYep, sNews, … to do. You would make a template page, apply the relevant Action, and depending on how the CMS works, either deploy a separate interface page for the client, or add a little “log in” icon in the corner of the page. Client logs in, creates the content, there is no step 3.
On May 24, 2013, at 10:22 AM, Robboxxx wrote:
Hi All
Well… Needles to say that the web yep action suite worked like a breeze after I followed Max tutorial. Now I’m experimenting further with it. It’s actually great fun.
