[Pro] A little left of center
Somehow, I seem to have gotten my layout off-center. I can’t seem to figure out what the culprit is. I believe it’s only showing up on my 320 breakpoint, and I believe the problem is on the master page. I’ve looked and can’t find anything that is off the pasteboard, but the way it’s acting, something must me.
The problem is most visible looking on my iPhone in vertical orientation.
Thanks to all!
Doty
Your problem is caused by the mercury mobile logo which doesn’t shrink down, keeping its width by 380px. This ends up in side-scrolling.
I recommend to set the pass-through image’s width to 100% rather than undefined (or flexible) or reduce its size on each breakpoint.
nice site!!!
so clean and subtil, I like that very much!
Could you tell the secret, which method you used for the nice slideshow?
Cheers,
Chris
