You’ve got a Google Maps error, requires an API key. Also, you are loading two different copies of Prototype.js which may be causing some problems for you as well. There’s a LOT of scripts on this one page, and I’m not sure which if any of them are throwing you off. Try adding your accordion to a new, entirely empty page, and publish it, and see if it works there. (My guess is that it will.) Then try adding one thing from this page at a time until it breaks.
On Nov 8, 2017, at 3:07 PM, billy kimmel email@hidden wrote:
Can’t get my div to auto open in my accordion.
Using the Add Selector I have created my class as “open”
