I don’t think you can do it easily Ernie. You can use an Action, insert the list as a markup item or edit the code after the page has loaded. Unfortunately the application doesn’t provide the same hooks to extend elements like lists, rules etc as it does for tables (for example) where you can inset code at various locations as well as add attributes to the table or cell.
On 1 Oct 2014, at 18:05, The Big Erns wrote:
I am blanking here… does anyone have an idea for adding a second class to a list?
Apply the Action to a parent object and give it the class to hunt for. Once located it will append the other defined class(es) to the object(s).
I do wish Freeway had nuts and bolts access to items like lists as they remain frustratingly out of reach without Actions like this.
Thanks for the attention guys - adding classes works well with some items,
but there are still quite a few ordinary bits that the Extended interface
doesn’t touch. I could make duplicate styles to cover the different style
combos but that seems so un-clever.
I usually end up making an inline Action (which goes into one of the LIs), and then reaching upward for the UL in the Action. It becomes unsightly to look at while designing, but does give you the access you need in the Action.
Hi Walter,
I agree. Other than pushing the design view around an inline Action would work well here.
I had thought that a generic Action that looked at the styles on the page and attempted to place classes in the HTML would work really well but I stopped when I realised that it would take me far longer than I had. The basic idea is that you could have two styles like this;
.mycolor { color:#cccccc; }
.mydiv ul { color:#cccccc; }
the first one being a Freeway produced style (a name style) and the second a user generated one (a tag style). When the Action runs it would have to look for the second nested style, locate a matching class for the style (mycolor in this example) and then locate the UL on the page to apply the mycolor class to. Finally it would need to clean up the styles once it was done.
In essence it would dumb down the CSS and simply apply the base styles to the HTML.
Needless to say I found this Action I wrote a lot easier than trying to tackle this! Maybe if I get time I’ll try and look into how this would work.
