Hello, I would like to add masters for each language to simplify the menus, such as master1 for everything, master_en for English, master_fr for French, and so on.
How would it be possible to link the pages to one master only and not to each ones?
Thanks for your help! Vincent
freewaytalk mailing list email@hidden Update your subscriptions at: http://freewaytalk.net/person/options
OK, I found it…
just create a new master, name it and then drag the master from the top to the destination folder to create a file. Rename it and it’s done.
since the new master isn’t influenced by the former one, everything must be copied manually before dragging.
