I want to add Soundcloud to my freeway-template, is there any actions I can use?.
Excuse my ignorance, but I’ve never heard of it.
What specifically do you want to add?
This is soundcloud: Stream Demi Broxa music | Listen to songs, albums, playlists for free on SoundCloud
and I know how I can get the code, but I can’t find any actions I can use for it.
And here is the code I want to paste in my freeway 7:
Not sure you are ever going to find a Soundcloud action!
The way I have done it with Mixcloud (which is similar) is to add another page that is the size of the soundcloud player and insert an iFrame action to it. You can add the URL to that action and then link that page to your website.
You may have to edit the URL to something like:
Insert > Item Action > iFrame
Paste the following URL into the URL dropdown of the iFrame parameters choosing Other from the options
https://w.soundcloud.com/player/?url=https%3A//api.soundcloud.com/users/67639623
Give your iFrame a name (in the action)
Size it to suit your layout
That should do it - http://deltadesign.co/FW7Test/soundcloud.html
I’d paste this code into a MarkUp-Item (Insert ->). This should do the trick.
This is a very old website I created before the days of responsive-anything. But it definitely can be done. Soundcloud updates automatically every week even though I’ve not updated this site in years: Agingless4u.com | Suma G. Nathan, C.N.C. |
Let me know if you need me to look at the specifics how I did it. I can’t remember if I did iFrame or a Markup item. One of the two, I’m sure. Good luck.
Doty
Thanks Doty but the OP seems to have lost interest in finding the answer - or just in letting us know about it!
