I just reported this bug to Softpress yesterday. The stylesheet is not being hosted from the same spot that the Action is requesting it. If you look in your console, you’ll see some 404 responses from the server for the css file.
On May 4, 2012, at 11:54 AM, Mr worm wrote:
Hi guys,
if I use the code the add this btn produces:
I get the initial icon I wish to see, but when th edrop down occurs its raw text & not graphical?!!
Does this only happen locally or is it happening on your live site, too? I was looking at this recently and found that their code must have recently changed and broken local previews.
On 4 May 2012, at 16:54, Mr worm wrote:
Hi guys,
It’s not a bug in Freeway (or anywhere, really). They’re using a shortcut that allows connections to files to be made securely without having to check for a secure connection first (protocol-relative URLs). This is a neat trick because it makes code shorter and cleaner – the downside is that it breaks local previewing. Unfortunately, we’re noticing a lot more script developers using this recently, which is making things like live previews, or local previewing much more difficult.
On 4 May 2012, at 17:00, Mr worm wrote:
Ok, at least I know theres a bug!!
Guess we just have to sit tight & wait for fix/update from softpress!
I had the same problem and had to remove Add This from my website and put in the main social media sites individually. I also had the same raft of script, in blue, published or not published, so would appreciate a solution.
