I have a FWP page that uses Carousel 2. I currently have only 1 Carousel 2 pane on this page, but I’d like to add a second pane. I also should mention that I’m using the Carousel 2 text Tab to cycle between the panes.
For some reason every time I attempt the upgrade my third text tab links to the first pane, even though it’s set for the third. Could somebody walk me through the process of adding an additional pane?
I figured out the problem and I keep forgetting to do this with FWP 6. In addition to uploading the FWP web page, you also need to upload the associated CSS file as well.
If you upload with Freeway, everything should be done for you.
On Jul 22, 2013, at 8:41 AM, RavenManiac wrote:
SOLVED
Hey Walter. Actually, I upload to my development server, THEN copy the updated files to my live server. That’s why I didn’t pick up on the issue at first.
