Robert_B
(Robert B)
November 9, 2010, 6:17pm
1
Is it possible through Showcase or through one of the similar actions in Freeway to add sound to a slides how?
I’ve see this on lots of sites and I guess it’s usually Flash, but it seems silly to use Flash for a slide show just to add sound.
Bob
You can use the background sound action to play or loop a sound when the page loads, but if some form of synchronization is desired you will need to resort to Flash or QuickTime.
Robert_B
(Robert B)
November 10, 2010, 1:02am
3
OK. Thanks.
Yeah, it would have to go with the slide show.
Bob
