Can the Bar location be moved?
I have installed an extension on my FW page and it appears to work perfectly, however I’d love a way to control where on a page the bar shows up by default. I find it a little distracting to have right above the title and was hoping it could be moved to be over on the right by default
Another problem I found is that the bar menu moved my title and menu bar down. They are in layers because I’m using CSS menus and if I put them as fixed windows they won’t work. Any ideas?
thanks
