I’m not sure exactly what is going on, but Freeway & Edge Animate are not cooperating correctly and I am suspecting that maybe an action will be needed to fix this maybe.
The link above to a new website that I started building tonight. The top banner I created in Edge Animate. When I want to add another Edge Animate animation to the same page, it seems which ever one is at the front takes over the page and only one of them will play!
I really think that Freeway is not able to properly write the Edge layers correctly and that it might require something like an action to fix this, as this happens every time that I want more than one Edge Animate animation on the same page.
Can someone come up with a fix? I think this will be a problem for everyone using Freeway and Edge together.
Hello, friend, definitely understand you, having the same problem. Unfortunately, I don’t have any solution to this, I registered to this community with hope, that someone will be able to help me, but after seeing your unanswered post, I feel disappointed a little bit. Now I don’t know what to do with my http://researchpaperwritings.net/ project.
