[Pro] Alignment issues in Firefox
I have a very basic page with separate textboxs (2) and a single small graphic. The layout works fine in IE, Safari, Chrome, Opera but in firefox the text line spacing is larger than the other browsers forcing me to adjust my graphic downward. I originally had all the text and graphic in one textbox (graphic box inserted) and again all was fine except for Firefox on MAC. Firefox on windows is fine although the font is slightly different.
I am sure I am making a simple beginners error. I just can’t figure it out.
It is the about me page on the following website:
www.bethandchuckdiveteam.com.
Thanks.
Chuck
I’m not seeing any problems in FF on Mac.
Maybe your zoom is inadvertently too large?
Go to View>Zoom>Reset (or command 0) to set it back to normal.
Bob
Bob,
Thanks for the quick input.
Interesting that is looks the same. If I do a 1x(-) or 1x(+) in firefox the spacing gets better but not the same as in all other browsers. To compensate for Firefox, I split the text and graphics and placed the graphic and second text box lower so it is tight against the text in Firefox rather than overlapping. That of course created a wider gap (but acceptable) in all other browsers.
I set up a quick site to post the clip I made of 4 browsers aligned side by side at the same zoom (100%)
http://www.aragonalliance.com/
Notice how tight the graphic is in the clip to the far right? That is FFX. Is that how it looked when you viewed it?
Chuck
Looks like the leading is bigger in FF on Mac, for some reason.
Make sure the leading is set to px and not percentage, maybe. Or, set leading in the p tag.
Bob
Bingo!
Thanks Bob. The leading was at the default setting (100%). When I changed it to any PX amount the FFX produces the exact same results.
Much appreciated.
Chuck
Great. Glad that worked out
Bob
