I am using Freeway 7 - Responsive Template (Assistant).
Using Master Page as foundation. Home page has a slider from Amazing Slider with a video. The CSS submenu above is disappearing under - z-index 9999 shows as strikethrough in Safari’s inspect elements.
The problem seems to be the slider itself. Is there a way to give the Slider, which is inserted into the Body Wrapper 1 a lower z-index? So that the CSS submenu appears above.
Tried many different z-index options and still no solution …
Thanks for any advice
-Rene
This is not how the actual new responsive site I am working on looks like - which is much cleaner, aligned and so forth. But I am trying to send you an example of the problem to the best of my limited knowledge.
The example of the submenu being hidden under the Amazing Slider is there for you to see. Hover over the EXPLORE option and you’ll see it (particularly if you size the safari window in tablet format).
I do not know code at all - so I might be doing this all wrong. However the “Assistant” template I have been using seems to work very well apart from my CSS submenu / Slider z-index issue.
Thanks for any advice again,
Rene
