Hello. I would like to make some movement effect on a page, like a picture that is slowly changing color, or the letter that make something to come in, or for example, that the background is a slightly moving smoke. All this thing I’d make them with flash, but it not possible now because of the iphone and ipad… you know they are blind…
I thought about animated gif, but this format is not fluid at all, and is so heavy.
On 15 Sep 2011, 7:47 pm, DeltaDave wrote: > > There is Hype for HTML 5 effects - if you don’t mind Epxloder users missing the fun. > > David > > > > > >
What is a Hype…?
And what do you mean, that Internet Explorer cant see this hype?
Can you please help me a little more? Where can I find information about these CSS3 actiosn or the hype you say?
Hype is a new HTML5 animation program. Think of it as Flash for the 21st century. It is compatible with iPad and iPhone browsers, and any modern desktop browser (IE 9 or better, all other major browsers from version 3 or so). You can download a free demo or buy directly at http://tumultco.com or purchase it for $cheap in the Mac App Store.
CSS3 is an emerging Web standard, supported by the same collection of browsers as Hype, that brings richer animation and visual styling to HTML/CSS. In fact, most of what Hype does is put a nice set of visual controls on these same CSS3 properties.
What is a Hype…?
Provided understands the very basics of web design, Hype is straightforward and with a little patience, one can have it working quickly without having to read the manual, which contains more than sufficient information for implementation.
Hello. I’ve bought Hype. It seems to be an editor itself, but in freeway, there are actions to include Hype in Freeway. How should I proceed? Installing these actions to use Hype with Freeway? The link I saw is ActionsForge - The Complete Repository of Freeway Actions
I had to get a hype file quickly added to a website, I tried Paul’s action but had problems - most likely self inflicted as I’ve never had any problems with Paul’s actions - but didn’t have time to troubleshoot so I did the Insert/Markup Item and uploaded the Hype export folder using Cyberduck.
I would try Paul’s action first as it will make life much easier down the road. If you want to try the method I use, email off-list and I’ll walk you through it.
Well, I have installed the action, and don’t know if other actions have disappear, but… sometimes, a man does what a man must do (literally from spanish, but don’t take into account, its late…)
I have followed instructions and try a simple animation into Freeway. It works!!
But here is a question: I send the hype object back, and other elements on the page to the front, but the collibri (hype little bird) is always at the front. Is possible to send it completely back? I would like to make a background with text over…
Thanks a lot. In this link you can see haw I can put html text and graphic text over the hype object, but cant put any image. (The gray square in a graphic object that I said to brink at the front)
