Hello. Is it possible to upload an animated gif to a WebYep image item?
I tried, but for me it doesnt work. It uploads the image, but on the web, you only see the first frame, not the animation.
Thanks.
dynamo mailing list email@hidden Update your subscriptions at: http://freewaytalk.net/person/options
hi Rakel yes you can upload animated gifs but they need to be uploaded at the same size as they intend to be used at. If webyep needs to scale them into the area you have drawn out, the animated gif will be re-saved at and only as a single frame.
All the best max
