I am working on my own site and would like to do the following - unsure if I should do a flash or random rollover or…???
My main graphic and logo is 4 puzzle pieces together.
what I would like to do is Have all 4 pieces apart then bring them (randomly separate or all 4 at the same time) into the final together look. I really just want this done at the beginning when someone comes to the site. / back to the home page
together look.
There’s an action called Move Layer that can do precisely what you
want. Select your (layered) object, choose Item > Actions > Move
Layer, and set the parameters: speed, x/y start and end point
relative to current position, loop on/off.
I can’t tell whether that’s a standard action or one that I’ve added
at some point in the past. I think it is a normal bundled one, but
shout if you can’t see it in your list.
I can not find it in 5 pro. Also I checked actionsforge and could not
find it there either…
which would it do the all at once or the randomly? - or both?? just
curious
J:)
together look.
I just took your logo from your site and opened it in Photoshop, separated the different pieces into different layers and then saved each layer as single PSDs.
Imported each ‘piece’ into individual graphic boxes, apply the action and fiddle with the settings to get them to come together.
Now if you created your logo in illustrator - or similar - you will be able to save each piece as a separate file and get much better quality than I did.
If you want I will send you the FW page so that you can see its construction.
Illustrator and Photoshop both debuted on the Macintosh, and were Mac-
only for many years after that. So if you are accustomed to using them
on another platform, you should use them on your Mac, where they will
be at their best.
If you don’t want to pay Adobe twice, then there are Intaglio (for
illustration) and Pixelmator for the raster stuff. Both are less than
$100 each.
On Mar 18, 2009, at 12:04 PM, Julie Maxwell Allen wrote:
Can any one tell me what an equal to illustrator and photoshop might
be in the mac / apple world or are they the best for graphic editing?
If you have Illustrator, then Intaglio is not needed. It’s a low-budget Illustrator-like application, but compared with the Adobe product, it’s more of a toy. That said, a lot of people love it and prefer it. But it’s not designed for the same sorts of things that Illustrator is.
ok … I have it working - but I need to Put it in its place ( I
left the pieces together to show where) also - i did the exact
"placement / x /y that David put in his sample - but they are not
coming together exactly…
I don’t mean to be stupid - but learning the tweaking on these
detailed actions is confusing sometimes.
Illustrator is.
is there a simpler way of dragging the objects into different places
and experimenting each time?
Illustrator is.
Mathematical calculations based on how far apart the pieces are from each other when finished also calculations of distances between start and end points. These figures then used to calculate the figures that go in the action dialogue boxes. Unless your graphics (and containers) are exactly the same as mine you wont be able to use exactly the same co-ordinates.
From your page I would say that you should be able to get your pieces looking better - without the rough edges.
Have you tried exporting the different parts of the puzzle out of Fireworks - I dont have the program any more but I think it does vectors and maybe even can export ai files?
FW can then import ai files and output them as png, millions of colours, to retain transparency.
