hi all,
new user here been at it all of 4 days an i’ve hit a wall using an iframe.
im trying to get pages to show up in a frame but im not being given the option of my particular iframe in the target pull down under hyperlinks.
so what ive done so far…
insert - action - iframe (given it a name)
(selected an image), image - hyperlink (select page i want) click target but dont see my iframe listed.
i hope this makes sense
any advice would be gratefully received
Sure. The Action won’t insert its instances into the Freeway application’s lists of possible targets. But that’s a “combo box” control – you can pick from within its presented options OR type your own. Simply type in the name you entered in the Action (case-sensitive) and all will be well.
On May 7, 2013, at 3:39 AM, pete wrote:
hi all,
